1990 Suzuki Swift Hatchback.
deb_nz, Mar 29, 1:58pm
Question: Do they have power steering and if so is it hydraulic or electric!And where do I find it!
morrisman1, Mar 29, 2:01pm
if it did, it would be hydraulic. There is a pump driven off a belt, which provides high pressure fluid to the steering rack. There will be a reservoir for the fluid somewhere attached to the driver's side of the engine bay. They normally take Dextron 2, or 3 auto trans fluid.
deb_nz, Mar 29, 2:03pm
Nawwww thank you, will get hubby to have another look.I hope they do, the daughter finds it hard to steer.
countrypete, Mar 29, 2:44pm
They don't have power steering.
theram1, Mar 29, 2:47pm
If it is not power steered, check the tyre pressure.
deb_nz, Mar 30, 9:36am
Ohhh, thanks Countrypete. Bugger!Thanks for the tyre pressure suggestion theram1.Will check that out.
