Coppper-nickel brake lines
elect70, Mar 28, 3:26pm
Probably not as copper isnt ,yet refrigeraration grade copper tube is better than crap bundy tube which rusts from day 1 . I redid my quad bike in it
woodsy2, Mar 28, 5:31pm
You need cupro nickel tubing for brake lines. A shop in Ashburton is agent for the tube.
ladatrouble, Mar 28, 6:07pm
Copper is legal for brake pipes.
sr2, Mar 28, 6:22pm
Copper brake lines have been illegal in NZ from the late 90's (they work harden).
Copper-Nickel tube (approx. 10 % nickel) "intended for brake lines" is OK.
ladatrouble, Mar 28, 7:12pm
It's not and has never been in the VIRM. They need to be secured every 300mm to stop movement which causes the work hardening.
jason_247, Mar 29, 7:15pm
im guessing the copper being banned is a cert requirement rather than a wof failure item?
akgaragesale, Mar 29, 7:17pm
Yes okay for WOF but not for Cert or Vin.
pauldw, Apr 7, 12:07am
Wouldn't the use of nonstandard material require a cert?
AFAIK the recognised tubing for brake lines is bundy steel and Cunifer or similar copper nickle.
