Engine mounts causing bad vibration at idle?
franc123, Mar 15, 10:43am
Yep, if they are broken, have hardened up from age or in the case of hydraulic mounts the fluid has leaked out they can certainly cause vibration. If one has failed the others may have been under more stress since the failure.
kazbanz, Mar 15, 12:11pm
Studio1-Busted engine mounts are one of several possible causes of vibes.
ozz1, Mar 15, 12:28pm
nice one kaz. :) good vibrations. eagles on to nite.
mechnificent, Mar 16, 8:51am
Sometimes they need setting up too. Some have slotted bolt holes so the mount can be slightly pretensioned.
lookoutas, Mar 16, 6:19pm
I was there, but didn't see the Beach Boys
jrlaw, Apr 28, 9:08am
Found a Toyota with rock hard mountings, vibrated for sure, fitted a new set of mountings and it was all fixed.
