Aux- in clues for factory stereo ?
ford_transit, Nov 14, 9:44am
Hi Guys,
Apart from the obvious replacement with a new one,
has anyone found a way to get a signal into the factory CD player
found in your average 2009 Swift ?
Seems a shame to lose the on wheel controls.
sw20, Nov 14, 9:51am
There will be a port on the back of the stock stereo that you can plug an aux adaptor into.
ford_transit, Nov 14, 9:55am
Heck that's good news :)
slacker8, Nov 14, 10:12am
Just a side note, I have a aftermarket pioneer headunit which still uses steering wheel controls. So there are headunits out there with steering wheel control if it needs replacing.
bigfatmat1, Nov 14, 10:50am
Most quality stereos support steering wheel controls
kazbanz, Nov 14, 11:05am
Ford Transit what he said ^^^^^^^&^^^^^^^^^^^^^
make sure that specific rradio supports the wheel controls but the decent stuff does.
ford_transit, Nov 14, 7:01pm
Thanks for the help Guys :)
wind.turbine, Nov 15, 10:19am
just upgrade it to one with all the new bells and whistles ie. bluetooth, pandora etc will have USB and AUX in
vivac, Nov 15, 6:25pm
Have actually just read about a device for this, intercepts into the aerial line. Called an iSimple isfm23 and retails for about 200. Uses Bluetooth thing to connect to your phone via an app.
sred69, Nov 15, 6:45pm
Make your own cable for a few $$$
http://www.swiftfive.net/viewtopic.php?f=26&t=156
You may need to sign up to get the pictures but if you can solder then it's pretty simple to do
bae13, Oct 13, 3:07am
install an FM modulator to the aerial, They are hard wired and give very good playback,
This way you can keep your controls and use the radio tuned in to your FM modulator and play your songs.
Get in touch with me if you want one
