My J1 Bedford has a Manufacturers Gross laden weight rating of 3401kg. Originally had a loading cert with a gross weight of 9375lb (4252kg). Registration died 1996. Can I get this back on the road without having to get through a COF as I intend this truck to be for only private use?
martin11,
Mar 11, 8:36am
Probably not email NZTA and get facts in writing .
Mar 11, 9:00am
anything above 3500kg needs a cof it dont matters what you think should be private or what ever has absolut nothing to do with that you always will need a cof . The weight is what the manufacturer has printed it to be at the time it was built . I had a client with a daihatsu delta i think it was the waight was now sit down 3550 kg on the printed lable. he wanted to change it to 3500kg so it could pass a wof. Sorry he was told its what it is and anything above 3500kg needs a c.o.f manufacturing specifications can not be changed . Possibly you could change it if you complete recertified the vehicle and then you open another can of worms with more rules and regulations you have to comply after i would guess plus the cost of all this would probably buy you easy another vehicle instead.
skin1235,
Mar 11, 9:05am
do motorhomes 3500kg plus have to have a COF? somewhere I got the impression they didn't, a WOF and RUC's if it was diesel
snoopy221,
Mar 11, 9:08am
Sheesh J 1 's ain't that heavy it musta been eatin all the pies-lol The J2 which is on T V as the food truck runs on a warrant from memory with the kitchen built in. Next time it's on tv carjam the rego. Reality is a J1 should be warrant class weight
martin11,
Mar 11, 9:23am
Vehicles were made out of real metal in the days that this was made in not tinfoil like new vehicles .
nzanthony,
May 6, 10:07pm
Thanks for the replies will contact VTNZ. My way of thinking is that the manufacturers weight states 7500lb (3400kg). The original MOT loading cert is 25% more at 9375lb (4252kg). I just don't understand why a loading cert allows more than what the manufacturer states and I reckon if I was to re vin this truck that it should be subject to the manufacturers weight limit of 3400kg.
