Help ! tips on removing stubborn spark plug lead
brokebloke1, Aug 24, 6:33pm
trying to remove sparkplug leads on a 350 chev and they are so tight on the plugs , does anyone have any tips on removing the leads
thanks
monaro17, Aug 24, 6:36pm
bolt cutters and buy a new lead and plug
mrfxit, Aug 24, 6:36pm
Heaps of crc on a slightly warm engine, leave for 10 minutes & spray some more crc, then try 5 minutes later
brokebloke1, Aug 24, 6:37pm
prefer not too but maybe a very last resort
brokebloke1, Aug 24, 6:41pm
may have too
mrfxit, Aug 24, 6:50pm
Why not, excess can be washed out later
skin1235, Aug 24, 9:42pm
grip low down on the base of the boot with pliers and twist, mostly its the very edge of the boot welded to the plug by heat, once you break the weld they slip off easier
skin1235, Sep 3, 1:15pm
and heat shielding the plugs from the exhaust will cure the problem in the future, even heavy duty baking tray ali is enough to stop the direct heat
