possibly unless somone removed it or stolen it or it never had one to beginn with. And v6 crack rear heads including toyota v6 engines.
fordcrzy,
Aug 8, 5:57pm
2grfe
melonhead1,
Aug 8, 6:15pm
Through not doing coolant changes?
panicky,
Aug 8, 6:26pm
1mzfe are the problem v6 Camry engines. Seen one rot the block to the point the water ports were so enlarged that there was not enough gasket contact to keep the water outta the cylinders.
andy61,
Oct 30, 4:18am
Are you sure?,I was always told to avoid the 3VZ series 3 litreV6 ,they were bad for corroding the block,causing the head gasket to fail.They were fitted to early Surfs and Camrys
