hi my 93 hilux tipped over 200000 kms the other day and the tbelt light came on the dash,now ive not long ago done the timingbelt,, so how do i turn off the light?
Jun 8, 5:49am
the hole in the dash glass is there a rubber bung? you have to remove it if you can press the pin iside the instrument . if not then you will have to remove the cluster and its at the rear of the cluster a screw has to be shifted there will be a empty spot of no screw and the oposite side there is a screw shift it over to the other slot. or the reset button is on the back of the cluster. that is all the possible ones
http://s40.photobucket.com/user/joinerman/media/Various090.jpg.html the front reset you will be able to reset by remove of bung from plastic glass dont make the bung fall in inspect look for that pin on cluster as you have to push it once with a knitting nedle or something
this button can also be on rear of cluster if you dont see in on the front
kat35,
Jun 8, 6:07am
ok will give it a go
skin1235,
Jun 8, 6:31am
some also use the trip reset, key off, press the trip reset for 5 seconds, do not release, turn key on, keep reset pressed for another 5 seconds, release, then press again for 5seconds, release and press again, release, key off, start engine
skin1235,
Jul 18, 12:14pm
ah yours has the mechanical numbering rollers odometer, the above is for the electronic odometer sorry
