Aprox labour cost to replace diff Holden 95 vr
mkenzi, Jul 4, 10:29am
Hi
Can anyone tell me how long it would take and labour cost to install below
Remove existing diff and install the second hand one that i have
Holden Commodore 95 VR
Solid Diff
Just curious to know ?
m16d, Jul 4, 11:08am
Do it yourself. jack the arse up remove drive shaft,pull axles. remove diff head, stick new one in, then put it all back together again.
with a bit of practice. 30mins.
ceebee2, Jul 4, 3:07pm
Plenty on youtube
gmphil, Jul 4, 6:37pm
if u change diff centres ul need shim properly so u get the backlash rite
if u a novis may pay change hole diff ?
mkenzi, Jul 5, 8:08am
Mine has abs attachment Lucky i found a diff as was more common for non abs OR IRS
gmphil, Jul 5, 8:59am
does it just have the rings on diff or do u have abs
mkenzi, Jul 5, 2:52pm
Who would you recomend to do this mechanic out
Waitakere City area Please
mkenzi, Jul 6, 9:08am
Mechanic out West ? anyone know aprox cost
franc123, Jul 6, 9:26am
You aren't going to get the same answer twice, its going to depend largely on who is doing the work and what exactly has to be changed over re brakes, rotors, park brake shoes etc and then setting it all up after its installed. If you've got two of each of these things you would want the best condition bits fitted to the replacement axle wouldn't you? I'd bank on at least three hours labour at whatever rate, garages tend not to like fitting customer supplied parts and generally jack up the repair times.
gmphil, Jul 6, 9:53am
franc 123 Is rite ! some or all of this can happen ! if I was to do id charge $280 theres a startng point for u !
franc123, Mar 21, 5:08am
Yes assuming no other bits absolutely need replacing and nothings broken or siezed. It goes without saying that some new oil for it would be a good idea too.
