Led daytime running lights
ianalice1, Mar 19, 10:45am
Hey guys.
Just wanting to get a wof type ruling on these lights.
I think they are a great idea, but I'm confused about the wiring.
I understood they were to turn on, when main key is on and turn off when park or headlights are turned on.
Seems most for sale, on here are just 2 wire and I thought would need 3 wires or some sort of relay setup.
So can you wof guys enlighten me?
Thanks,
Ian.
frytime, Mar 19, 10:49am
Correct. I've powered mine off low beam earth wire (earth switched lights). Works for me
clark20, Mar 19, 10:50am
Here's a site with all the info
http://www.safetydaylights.com/
And you are correct, typically a changeover relay to turn them off when the headlamps are on
ianalice1, Mar 19, 10:52am
So that being the case, why are they to sell them, as would be illegal?
ianalice1, Mar 19, 10:54am
It says this, They automatically switch ON when the ignition is switched ON and will automatically switch OFF when the headlamps or park lights are turned on.
I thought I was right, for a change that is.
wind.turbine, Mar 19, 10:59am
Note that if you follow the rule book by the letter it means that they can stay going when position lights are an but must turn off when (main) headlights are turned on
clark20, Mar 19, 11:00am
Some come with a relay and some do it internally (3 wires). There is a new automatic relay
http://www.safetydaylights.com/product-range/the-complete-range/safety-daylights-smart-controller.html
ianalice1, Mar 19, 11:02am
Just found these ones and they almost $100, plus fitting. HELLA LED Safety DayLights
richardmayes, Mar 19, 11:42am
I just use the old-fashioned headlights. Supplied free with every car.
inkapuka, Mar 19, 11:44am
My old car had some i purchased on here and when lights go on they just dimmed all legal
ianalice1, Mar 19, 3:50pm
There is so many on here, I guess it's a matter of getting the correct ones.
But I don't know which one?
clark20, Mar 19, 3:56pm
First make sure they are compliant (ADR or ECE)
Then get high efficacy (2-3 watts each)
Then make sure you get a 5 year warranty
clark20, Mar 19, 4:05pm
Yep, and bulbs then wear out quicker, and you need 0.1-0.2L every 100km to power 110W
gsimpson, Mar 19, 5:09pm
Doesn't make much diiference as one should not be driving on park lights only anyway.
o0_hamburger_0o, Mar 20, 11:32pm
see too many of those around even at 9pm on way home from work
o0_hamburger_0o, Mar 20, 11:35pm
not to mention your battery guarenteed to be flat if u forget to turn lights off when parked for few hours. whereas LED uses SFA power.
richardmayes, Mar 21, 7:29am
Oh I see. LED lights would save me a COOL 20c EVERY time I drive to Palmerston North. I guess that would eventually add up to. something? (A set of LED lights perhaps?)
I was taught that you check auxhilaries like lights, wipers etc are off before stopping the engine, and that this is just a core part of driving that you always do, so leaving lights on to flatten the battery is of no concern to me.
ianalice1, Mar 21, 8:30am
Good point.
But I have seen a police car, driving, with only park lights on.
Tut, tut.
ianalice1, Mar 21, 8:33am
Thanks guys, for all the feed back.
Think might need some of these, as cars often pull out, from intersections like I'm not even there.
I will turn headlights on, as and when required.
IE, heavy rain, etc.
A few days back we had hospital appointments at 8am and left home at 07:30.
Wasn't to light, so had my driving lights on.
Found very few had theirs on.
Mind you, my wife keeps telling me, Matthew 7:1-2, ???Do not judge, or you too will be judged. 2 For in the same way you judge others, you will be judged, and with the measure you use, it will be measured to you.
rovercitroen, Mar 21, 10:54am
I fitted a pair of day running lights to my NA Mazda MX5. The stayed on with park lights but went off when the headlights came on. I didn't want to drive during the day with the MX5 pop-up headlights up so I got the day running lights. My car was dark green and I had a few close calls where people pulled out and just didn't see a small dark coloured car.
wind.turbine, Mar 21, 11:28am
I only have just the position lights on when towing during daytime so the trailer lights are on, in poor lighting or at night main headlights are on as well
zephyrheaven, Mar 21, 12:16pm
Ive fitted them to mine and my wifes cars, we live on a 100km stretch of tourist roads & have had a few close calls with campers wandering on corners, more so the farmers with little or no lighting pulling out in bailing and tractor equipment - no problems since & that was a good 9 months ago.
I cant recommend the use of them enough, they dont make you bullet proof but they do make you visible from many miles away.
ianalice1, Mar 21, 1:53pm
Ours is silver metallic and thought was a safe car, but the amount of times I have to slow down, with in inconsiderate drivers pulling out.
seadubya, Mar 21, 2:00pm
Yep, some people don't even see you with all lights blazing, that's when you need http://upload.wikimedia.org/wikipedia/commons/2/2f/M240_CROWS.jpg
poppajn, Mar 21, 2:18pm
Still illegal isn't it?
