Compression joints on brake lines, are these permitted for a NZ WOF?
Thanks!
mrfxit,
Feb 1, 7:50am
Hell no, if it can slide on, it can slip off. Seen plenty come loose on std fuel & air lines, never mind the much higher pressures on brake systems
sr2,
Jul 14, 4:47am
Compression fittings were never intended to cope with 2,000 plus PSI, you'll need to use a double flare.
