Google is not being very nice to me,I want to know where the fuses, relays and or control units are for the electric windows 1993 Nissan Terrano
goron56,
Jun 2, 4:50pm
Fuses are under the dash in front of your right knee when you are sitting behind the wheel. relays are under the bonnet
Jun 2, 5:32pm
peter--if it helps at all. Normally if some do work its not the fuze.
petermcg,
Jun 3, 6:32am
Yes that is what I have, there does not seem to be a fuse for the power windows under the dash, and all windows work except the drivers, the full drivers control is out and it will not operate any of the windows
ceebee2,
Aug 8, 12:14pm
Usually a faulty drivers door switch controller. If you can actually dismantle door window controller and clean the contacts usually fixes it but if it has electronic contacts will have to be replaced entire in my experience.
