Any suggestions on a broken sun visor.?
millna, Jan 1, 1:46pm
I have a 93 Daihatsu Charade with a broken sun visor (that I currently Velcro up). I can't seem to find a replacement, does anyone know any if any other make/model of car that will fit. I don't care what it looks like as long as it functions. can new holes be drilled in ceiling of car to fit another model. ?
mischieftam, Jan 1, 2:35pm
try pull and pay dunedin- take a sample with you- probably piick one up for $10.
http://pullandpay.co.nz/used-car-parts-dunedin/
stornello, Jan 1, 2:45pm
Swap left to right sometimes works. if they aren't handed.
toyboy3, Jan 1, 2:46pm
Take the passengers one off and use that , only drivers one needed for WOF
dan14502, Jan 1, 6:55pm
drive away from the sun
buyit59, Jan 2, 8:57am
drive it at night . thats what my kids say I should do with my wifes Daihatsu Sirion .
skin1235, Jan 2, 9:01am
which part is broken, the base that screws to the roof only controls lateral movement ( side to side) and a solid mount point, if it falls down continuously the base is probably okay but the adjustable clamp inside the visor itself that grips the shaft is probably broken or mal adjusted, both can be repaired with a little ingenuity
skin1235, Jan 2, 9:02am
if the mount screws are stripped,, drill the plastic mount holes out a size and fit larger screws
lookoutas, Apr 4, 5:38am
If you've gone to the link, they have the right car.
