Hiace headlight alignment
daniel993, Jul 14, 8:07pm
How do you adjust alignment of these headlights?
ml6989, Feb 8, 4:11am
Depends on the type of headlamp. The older ones are adjusted from the front outside the vehicle. The later ones are adjusted from behind the lamp inside the vehicle, you will need an 8mm socket and a small ratchet and extension bar. Be careful, many of them are half siezed and if you are a bit "ham fisted" you can easily strip / break the adjusters.
