white vapour came out of the ventilation slots inside the car,had AA check for wiring smoking/burning . nothing burning/check was negative (not wiring) what would cause the air con vapour to suddenly release and vent into the car ? 2000 Saab 93 ;thanks
johotech,
Oct 31, 5:10am
It can just do that from condensed water vapor in some conditions. Is it still cooling now?
kevlight,
Oct 31, 5:32am
nah the air con hasn't worked since ive had the car about four months ,took a 100kl drive on a stinky hot day, and it wouln't cool car down .the next day went to the local super market ,about 3klm away and the white vapour just poured out the vents with the fan on ;
johotech,
Oct 31, 5:43am
Might have broken a pipe and dumped the gas when the vapor came out. Did the vapor smell?
Oct 31, 5:48am
Evaporator leak I'd have thought, Its the only refrigerant component that could leak into the heater box.
tony9,
Oct 31, 6:33am
Pollen filter blocked. Not enough air going thru when air con on so it has iced up.
Next day ice had melted and water vapour coming out.
Check pollen filter, what type of car?
Oct 31, 7:14am
my money is on a leak in the AC
tony9,
Oct 31, 7:36am
Is the air con compressor running? If so, I want some of your money ;=)
Oct 31, 10:45am
well if you check if the ac compressor is rotating when you turn ac on or not then you know if its no longer rotating the low pressure switch has triggered a no clutch turn on possible , reason would be your refrigerant escaped thru the burst evaporator in the dashboard
bigfatmat1,
Oct 31, 10:50am
Leaky heater core. Had a navara the other week that let out white smoke out the heater vents, was the heater core common on that vehicle. Tended to only do it when the ac was on obviously hot leaking onto cold causes it in that scenario
Oct 31, 10:55am
re 10 that would be the next thing if the ac still works . usually there is a wierd smell of hot coolant it has a destinctive smell and the coolant level will go down if you got a leaking heater core.
kevlight,
Dec 10, 7:25pm
okay thanks thats given me enough to go on, to check things out thanks for your help ; great motoring help ,thanks again
