It was a running change in about 1986 which was only about two years after the Surf model was first created. There's bugger all of them in NZ.
mrfxit,
Apr 16, 6:40am
It was an option from about 1984. You could get either live or IFS. All the "Surf/Prado branded from about 1989 had IFS front & coil rear http://en.wikipedia.org/wiki/Toyota_4Runner
Mar 12, 4:11am
its not what box it has its what engine is bolted to the gearbox. usually L engine was used till mid 90s to the same bell-housing . otherwise explain your question more correct the difference is in the differential ratios i would say.
