Mazda Axela heater control panel
toyboy3, Oct 3, 5:57pm
Is it possible to repair the circuit board as the fan speeds not working
bigfatmat1, Mar 31, 11:15am
Is it the one withe two dials of that one controls the fan speed the other the heat? If so yes it is possible Pull it apart don't pull the screws out of the dial until you have it apart. Unscrew dial carefully dismantle dial and use a epoxy glue to reglue contact on bottom of dial reassemble.
