Are our seatbelts handed?
trogedon, Sep 24, 3:32pm
Our Sentra needs another driver's seatbelt. Would a passenger one fit?
jmma, Sep 24, 3:38pm
No the mounting will be different.
Seatbelts handed? (o:
Please don't mess around when it comes to seat belts!
kazbanz, Sep 24, 4:05pm
the seat BELT is not specific to a side of the car.
But the retractor mechanism IS.
It will mount up but wont work,
lookoutas, Sep 24, 4:11pm
Have a look at both sides trog. If they look the same, they're ambidextrous.
(Jeez - that didn't get a red line under it!)
kazbanz, Sep 24, 5:17pm
wanna sell a watch mate?
franc123, Sep 24, 6:41pm
All belts are sided and usually will not work properly if not fitted in the correct position, it may not pull out correctly and the dual locking system won't work either. This is tested at WOF.
trogedon, Sep 24, 7:22pm
Na, I might get ticked off!
kazbanz, Sep 25, 5:36am
Best I hand you over to the experts then
socram, Sep 25, 6:39am
Can't remember the exact figures, but the numbers on the retractor dictate which way the belt goes ie the belt on the right will exit the mechanism with the expectation that belt is going or pulling slightly forwards. Put it on the opposite side and it will be going the wrong way. The link below and putting in Sentra shows a different number for the passenger side and the driver side.
http://www.apvsafetyproducts.com/seat-belt-replacement-guide
PS: I bought my web grabber belts from the local supplier, but used APV belts.
_peas, Sep 25, 4:34pm
All belts are not sided. Generic aftermarkets are sold based on the mounting angle. The most common were the 80/90 (and the other side 100/90) which were indeed handed. There are 90/90 mountings however. If your retractors mount straight up then it is quite possible that they could be swapped (not sure what you hope to achieve though).
kazbanz, Sep 25, 7:50pm
On the Face of it you might be right troggy
jmma, Sep 25, 8:27pm
Time will tell (o:
kazbanz, Sep 26, 5:07am
The sands are going through the hourglass.
kazbanz, May 7, 12:31pm
Hey sorry guys-I know the actual car concerned so know that the left wont switch to right . troggie is almost my neighbour.
