Has anyone one done cam adjusters on one of these? Does the engine need to come out? Or can you take the back of the head off release the cam chain tensioner. Take the cam pulleys off and slide it out under the cams?
bigfatmat1,
Sep 26, 3:17am
W8 engine
poppy62,
Sep 26, 4:43am
Hey BFM try this for a read, you may find something relevant and useful.
Thanks I had a read. I am still not sure what course of action to take.
thejazzpianoma,
Sep 26, 7:55am
1. Not done one. 2. Yes you are supposed to remove the engine from memory. 3. Good news is it's supposed to be a fairly easy one to remove as was designed as such. 4. Applying over voltage to the actuators above is common practice and a good first step (actually first step would be doing so via vcds at normal voltage). I have never seen such a good write up on the practice though!
Just going from the stories I have heard over the years. Usually, you can get away with freeing up the actuators. So I would concentrate my efforts around that first.
Sorry not much help, I generally avoided them due to the transmission issue and now find the next model is cheap enough not to bother. Nice car though!
bigfatmat1,
Sep 26, 8:24am
Already tried all that the exhaust one is stuck. But yes looks like engine out. :-(
bigfatmat1,
Sep 29, 3:22am
So $2800 for the cam adjuster one each side so 5.6k engine out timing chains, Tensioner, guides, Might get some change out of 12k
slarty45,
Sep 29, 3:33am
Far canal
johotech,
Sep 29, 3:48am
Time for an upgrade. Jazz will probably give you $500 for it.
berg,
Sep 29, 4:29am
Ouch! How many kms?
Sep 29, 5:11am
did you look and mail rexbo.eu for a price?
bigfatmat1,
Sep 29, 5:22am
na just speed
bigfatmat1,
Sep 29, 5:22am
200k no sign of engine neglect when I had one rocker cover off
bigfatmat1,
Sep 29, 5:24am
it also needs a secondary air pump and purge valve. A alternator and possibly a fuel pump so around another 3k. Guy is just going to drive it till it dies.
bigfatmat1,
Sep 29, 5:28am
I actually tried 12v nothing so pulled inlet off and rocker cover forced the solenoid off the valve breaking the three metal tabs. Then forced the valve down and worked it till it was free. I am however not confident there is a metal gauze that is floating round loose in the assy. Now runs smooth and no cam sensor codes
johotech,
Sep 29, 5:58am
As you seem to be up for any options, I have a couple of very large hammers I'd love to try out on a VW. I promise I'll try the smaller one first. (Don't tell Jazz though).
ema1,
Oct 1, 6:48am
No No no joho. hand genades could blow up given the hammer treatment, don't need a hammer actually, well a mighty big sledge hammer would be one I'd consider . . sorry bfm I wouldn't have one of them on my conscience. but good luck with it whatever way it turns out?
ema1,
Jan 6, 5:13am
Eeeeuuuuw yuk. boat anchor, or land fill?
