Heater for small generator?
stuffed, Jul 10, 1:00am
I have a 5 KVA hard wired (to our home switchboard) electric start generator that sits in a covered porch area but still gets damn cold in our southern winters and is sometimes takes a bit of starting.
Any suggestions for a semi permanent heating solution?!
Thanks
poppy62, Jul 10, 1:03am
Why don't you make an insulated cover for it when it's not being used? Plywood box / polystyrene lined should make a big difference.
tweake, Jul 10, 1:08am
insulation only works if there is heat in there in the first place.
so its a case of doing both.
do you get enough sun on that spot to keep it warm?
otherwise your looking at something like a coolant/block heater, or even just a small electric heater on a thermostat, in well insulated box.
s_nz, Jul 10, 1:15am
Block heaters are common in some parts of the world. do some searching for one that matches your generator.
Often they work by replacing the oil sump drain with an element.
If that fails, there are stick on ones, that you stick to the engine sump.
Many standby generators I see in commercial or industrial settings have heater on them to ensure they start easy, and ramp up output fast when needed.
stuffed, Jul 10, 1:30am
Thanks and should have said but have Para rubber panels on all sides - about 25mm thick.
poppy62, Jul 10, 1:31am
An insulated box with a 60 watt light bulb on, in it will supply the necessary warmth.
stuffed, Jul 10, 1:32am
Great idea thanks
the-lada-dude, Jul 10, 1:48am
that makes more sense ! . doesn't matter how much insulation you have, the unit when outside will always come down to the ambient temperature
tweake, Jul 10, 1:58am
put at least 100mm insulation around it. 25mm is nothing. but most importantly make the top air tight.
eg glue the top and sides together so it all lifts off when you need access.
that will hold hot air in.
if there is any gap at the top hot air will flow out and cold air will be sucked in and that kills the temps. especially if you use a low wattage heater.
use a thermostat. even better if its fitted to the engine. that way it will turn off when th engine is warm enough.
otherwise you will chew through lots of power trying to keep it warm.
mrfxit, Jul 10, 2:28am
Minus windchill effect which can double the low temp
muzz67, Jul 10, 2:56am
Are you off grid? If so, any heater is going to mow out your battery.
A small incandescent bulb is your easiest solution.
tweake, Jul 10, 3:24am
a 60w heater uses the same power as a 60w light bulb.
you can get those 20w heaters if you want.
stevo2, Jul 10, 3:57am
Insulate a box for the generator to sit in. Then install a heated towel rail (From 45 watt to 100watt) inside the box. Available from only $28 from Bunnings.
Install a timer if you only need it to run at certain times.
https://www.bunnings.co.nz/our-range/bathroom-plumbing/bathroom/bathroom-accessories/heated-towel-rails $28 version https://www.bunnings.co.nz/arlec-3-bar-45w-white-small-heated-towel-rail_p00305154
gpg58, Jul 10, 4:23am
Heat pumps, (opps)not for genny but to heat house.
If a decent clean supply, no reason to not run electronic stuff.
I ran all 3 (then, have 4 now) of mine thru the quakes, on a 5kw diesel cheap Chinese avr gen.
Nothing else will give you 1.5 x power used in heat output(full load operation) , or 4 x power used, at low to moderate output.
My gennys, i drilled a small hole in aircleaner of each(opposite carb throat), and give a puff of "start you bastard", before i even try first pull, or crank, they Usually go first try.
pacewaikato, Dec 1, 2:13am
Cupboard or wardrobe heaters.
50 or 100w options are available
Has a built in thermostat and around $125 from electrical wholesalers.
