Looking to purchase a 5 series V8 probably '05 to '10 with under 100ks. Any known issues that I should be aware of. TIA
_frodo_,
Sep 7, 8:41pm
Check the cooling system thoroughly - plastic parts become brittle and break.
mopeds,
Sep 7, 8:43pm
The earliest e65 v8's used an aluminium block with a hard chrome bore which became the source of many warranty claims, beware of buying a low milegage example that may not have any obvious issues, later models went back to a cast iron liner.
flack88,
Sep 7, 9:18pm
The m62 4.4 litre camchain flys to bits regularly,it looks like a bike chain from the Wharehouse.!
gedo1,
Sep 7, 11:23pm
Check if it has ever been parked up at the sky park at Auckland Airport
mastertechno,
Sep 8, 4:25am
Water Pump, Cooling system as mentioned by frodo , Brake discs, Brake lines, Shock absorbers, Steering Geometery , Fuel Lines. Get "Autosure" for sure.
trogedon,
Sep 8, 4:29am
Gas guzzling luxo barge. avoid.
bigfatmat1,
Sep 8, 4:34am
Oil leaks
ceedoubleyou,
Sep 8, 4:36am
bushes in the rear suspension are a big problem, when they need replacing, they fail WOF checks
rbd,
Sep 8, 5:52am
Expensive electronic modules failing with no warning (experience). If a wagon the wires into the boot break in hard to access locations.Check for water leaks into the boot at the sides where the fuse box is. Check for water damage in the electrical components under the spare wheel at the lowest part of the car (German logic that location).
BMW engines (and ZF gearboxes) leak like sieves. Sump gasket costly to replace.
tamarillo,
Sep 8, 6:29am
Don't, under any circumstance get one of these GTs. So ugly I can't look. Sedan or wagon both brilliant. Enjoy.
bigfatmat1,
Sep 8, 7:23am
Oil leaks in eccentric shaft sensors can easily climb into the thousands of dollars and cause misfires.
diddi1,
Sep 8, 7:05pm
Wow, that's just about successfully scared me off. I might have to think about a similar Mercedes Benz. I will start a new thread for that. Failing that an XR8 is starting to sound quite appealing. Thanks guys
saxman99,
Sep 8, 7:51pm
Gas guzzling luxo barge. Brilliant, get one!
sw20,
Sep 8, 11:07pm
May as well make hay while the sun shines trog.
These V8s aren't going to be around forever with the push for smaller turbocharged engines, hybrids and EVs.
elect70,
Sep 8, 11:17pm
As i found to my great expense BMW stands for big money waster , avoid .
trogedon,
Sep 9, 5:13am
Dang, I forgot those last three words! Big slugs like that - driving one would be like making love to a 20 stone woman - it could be done - but why bother when there are slender women with some finesse to horizontal folk dance with.
slarty45,
Sep 9, 5:16am
break my wallet. at the stealership
hkjoe,
Sep 9, 5:41am
Agreed, but not as ugly as an X6 in my opinion. The first time I saw one, I thought of a cockroach taking a dump.
saxman99,
Sep 30, 6:16am
Lol! Good on ya mate.
