ive given you help already ,the wof sheet dosnt give enough info , "worn" and just an F is just not enough to be accepted ,"worn out" makes more sense ,did they not give you a brake performance sheet ,after all you paid for the brake test. I see your point an agree , seems enough meat,but if there was no mention in comments or discussion per the fail with the tester id dispute with them on a recheck .they are either near borderline or near due for replacement or perhaps 80% worn , just a check box . ticked as worn does not cut it with me.with no comments to mention .But the old saying if in doubt biff it out . sounds like a shit outfit rushed thru by numbers and little time for the customer.
gph1961,
Oct 12, 6:28am
can we move on now?something more interesting awaits with luck
Oct 12, 7:02pm
Lesson learned--don't go back to that wof place.That said with pads only $50.00 a set you likely had half the job done by the time you were at the measure them stage. .Might as well toss a new set in
bobinnz,
Oct 12, 11:00pm
gph1961 wrote: can we move on now?something more interesting awaits with luck[/quote
You are welcome to F OFF as you have been as useful as tits on a bull!
gph1961,
Oct 12, 11:55pm
an angry person you are
marte,
Oct 13, 5:24am
LoL @ 'Triggered'
tygertung,
Oct 31, 12:42am
I like to use the Bendix Metal King pads as they are grippy when the discs are hot.
