What's the proper name for a car's 'door stop'
zak410, Jul 21, 2:35am
Similar as this photo :
https://imgur.com/a/p1ASmBF
I'm looking for one to replace a broken one in a front door of a Toyota Fielder 2011.
Any advice about where to get one from, and also does anyone know if they can be replaced without removing the door lining ? Cheers.
gunhand, Jul 21, 2:36am
Check strap.
And a lot of the time, yes, quite easy.
kazbanz, Jul 21, 2:50am
Sorry bro--Nope
yep its called a check strap but the 2011 fielder you need to remove the mechanism from inside the door.
OP don't panic --removing the door inner skin is really easy theres one screw in behind the door handle cover -one screw down at the front of the arm rest area--you'll see a line in the moulding. The rest is just poppers.
run your fingers along and theres a gap you can pull the skin away by. Then undo the two mounting bolts for the strap and it will fall inwards.
gunhand, Jul 21, 2:52am
I covered my ass and said, a lot of the time. I have changed shit loads of them, but there is always something different out there.
zak410, Jul 21, 3:00am
Thank you both very much, will check Toyota for the part.
kazbanz, Jul 21, 3:03am
Id grab one from a wrecker.Its not something Im commonly replacing
kazbanz, Jul 21, 3:04am
Sok--I went out to a car to check :-)
gunhand, Jul 21, 3:04am
LOL,, Cheat.
zak410, Dec 20, 11:54pm
Best service in town here.
