do you know what the offset is on the old 5 stud 13"rims eg pre hq like the torana please and thank you
gpg58,
May 30, 7:05pm
Goggle result, if any use. FE - HR: PCD 5 on 107.95 mm (4.25"), Offset 6mm positive. HK - HG: PCD 5 on 107.95 mm (4.25"), Offset 30 mm Positive (except HK and HT GTS which had an Offset of 13 mm Positive, HG GTS went to 30 mm Positive)
HQ - WB PCD: 5 on 120.65mm (4.75"), Offset 30 mm Towards the inside of the rim for standard offset wheels.
Torana LJ/LC, LX/LH: PCD 5 on 107.95mm (4.25"). Same stud pattern as HK-HG.
Torana LH with option L34 and LX with option A9X: PCD 5 on 120.65mm (4.75") with -1/4" Offset. Same stud pattern as HQ-WB with a different offset.
4 cylinder Commodores VB,VC,VH and VK are also the same stud pattern as a Torana and are also 13". HT, HG and HK are also the same pcd but are 14"
differentthings,
May 30, 7:44pm
Don't know the offset of them though
xs1100,
Aug 1, 9:57am
cheers found that after GPG appreciate yr effort,different things yeh thats why i said pre HQ and 13 but thanks for everything else. Just updating a caravan axle from Torana to modern Falcon and needed offset for new axle and wheels being zero offset
