Lost the original touch-up tin and wanting the original name of the paint (not a modern equal) for a Mazda Astina GT 1990 series BG 6.3. Would be so grateful. Thanks
curlcrown,
Apr 30, 5:26am
Somewhere on the car will be a tag with the paint code.
Apr 30, 5:28am
I had a 1993 Astina import and the code was on a sticker on the door pillar. This may be different if yours is NZ new.
gammelvind,
Apr 30, 6:45am
Is the name required simply for your own information? If you want a new touch up tin made the paint code is what is required as paint names are basically meaningless being that there are so many different shades of colour all with the same name.
clark20,
Apr 30, 7:04am
Mazda Astina GT 1990 UF – Clear White, maybe
zuggle,
Apr 30, 7:30am
Thanks Clark but I think that is the paint car sprayers use as the closest to it. I don't recall the name on the little tin being that. In answer to other suggestions, yes I have checked the driver and passenger door pillar for the paint code and it has only a sticker for tyre pressure, likewise the firewall. The car is NZ assembled.
zuggle,
Apr 30, 7:34am
Yes understood but going for a bigger job than a touch up tin can help with.
sr2,
Apr 30, 7:53am
Ring 'Car Colors', give them your number plate and they'll look up and supply you with the right paint (anything from an aerosol to a few liters).
With kiwi new vehicles of that age the paint code was often on a sticker on the firewall.
zuggle,
Aug 15, 4:58pm
Yes Kabanz, that was my understanding too (see No 6 comment) so I went back and did a bit of a clean this time and voila - there it is! So thanks for the nudge and thanks too Clarke because you were right - it's UF clear white. Brilliant! Thanks everyone.
