2006 Subaru Legacy EJ20 non turbo too higher k's?
doglover2003, Oct 14, 7:27am
2006 Subaru Legacy B-Sport wagon - what sort of mileage do these start costing a lot of money ?
Cheers
ryanm2, Oct 14, 7:55am
If it has a good service history they can go for ages, and ages like most modern jappas.
bigfatmat1, Oct 14, 7:57am
as above depends on service history.
sw20, Oct 14, 9:30pm
As above totally depends. My old 85 Corolla GT was at over 370,000km and didn’t leak nor use a drop of oil. The newer FXGTV which I replaced it with uses and leaks oil and has half the mileage.
kazbanz, Oct 14, 11:17pm
Whats a lot of money?
I would count on a $1000 bill at/about every 80-100k (closer to 100 in fairness) -that being for rocker cover gaskets/cam belt/water pump
meow_mix, Oct 15, 1:24am
Earlier Legacys from the 1990s were known to be a bit fussy and require a lot of maintainance, but the 2006 model should be very reliable, the EJ20 engine being a well-proven design. The 2006 will be the 4th gen and probably the facelift model which is nice. If it is getting on for 200,000kms then it should still have quite a lot of life in it, but as above it depends on it's service history.
doglover2003, Nov 7, 3:58am
Cheers guys for the tips and advice appreciated I'll look for a one with good service history.
