Mitsi problem
rico1993, Nov 12, 6:32pm
hey i have a 1996 mitsibushi legnum and just had to replace spark plugs so i did but then i didnt have any spark at all will that be a computer problem or an engine problem, i checked the engine fuse but that was alright any ideas !
andrea_w, Nov 12, 6:38pm
Did you have spark before you replace the spark plugs!
If so, I'd advise you recheck everything you touched to make sure all plugs are reconnected
phillip.weston, Nov 12, 6:39pm
what engine!
panicky, Nov 12, 7:23pm
IFS !Did you hook anything up wrong at all!
rico1993, Nov 12, 7:35pm
the car died so i checked the spark plugs only (3) just because of akward placement of the others (3), spark plugs were rooted ,i didnt check for spark before i installed them so not to sure.
the engine is a V6 non turbo
no
phillip.weston, Nov 12, 7:45pm
so all 6 plugs changed! check the distributor cap and rotor too - I had my '97 Legnum V6 die on me because of a faulty coil to rotor prong on the dizzy cap. With all the repeated attempts at trying to start before replacing the dizzy cap, the plugs were saturated and the engine was flooded. Replacing just the front bank of plugs didn't get it started but once all 6 plugs were replaced it started up first try.
rico1993, Nov 12, 8:05pm
thanx phillip ,we tried looking for the coil but no luck finding it. is the 97 and 96 similar! if so could you direct it to me!
phillip.weston, Nov 12, 9:05pm
the coil is built into the distributor. the whole distributor assembly is the same for 1996 through to the last of the NZ-new Galant V6 sedans in 2006. Even the 2L V6 Legnum (1996-7 years only) has the same distributor and cap.
fryan1962, Nov 13, 6:23am
Those back plugs are a bugger put long life plugs in there
rico1993, Nov 13, 6:33am
how would i test to check if the coil is working
mugenb20b, Nov 13, 7:29am
Nah, rather do Mitsi plugs than V6 Camry. Fit platinum tip plugs all round.
rico1993, Mar 12, 9:57pm
oh okay
