Battery is fine. ABS lights up on the dash, as well as the gear selector (on the dash). But then nothing when i turn the key further. Alarm still works fine (no immobliser either).
Any ideas!
tigra,
Nov 15, 2:41pm
What! no sound from the starter! Do the dash lights dim!Is gear selector in Park!
All very easy things to check. Do it and report back.
hydroman08,
Nov 15, 3:01pm
Well i got it cranking/clicking.Quite fast, but still wont start. All lights on dash are there (some dimmer than normal). Yes its in park :) Stero is not working either
henderson_guy,
Nov 15, 3:05pm
Sounds like the battery - how did you establish it was "fine"! Also, could be the terminal clamps need a clean.
hydroman08,
Nov 15, 3:07pm
Used my multimeter on the battery :) Alarm shouldnt work if battery is dead,or lights. However central locking isnt working.
henderson_guy,
Nov 15, 3:13pm
Have you put your multimeter on it whilst cranking! It takes a lot more battery power to start a car than it does for dash lights, alarms and central locking.
crzyhrse,
Nov 15, 3:23pm
Low battery voltage. It's dropping off when loaded which points to an unservicable battery with just a surface charge.
hydroman08,
Nov 15, 3:38pm
Well you guys know more than me - time to buy a new battery i guess.Old owner never wrote date of purchase on so dont know how old it is!
Nov 15, 5:23pm
That will tell you SFA.
mellisa2000,
Nov 15, 10:26pm
Fixed. Fish
the_don_61,
Mar 7, 3:50am
check the dofer on back of ING switch . comen fault.
Plus one of the relays under the hood.Try unpluging all relays and repluging them (dirty contact) plus two black relays by battery.Tap the top of them with your hand.
