i have just pluged my rb25de into my cefiro. i turned the key and no dash lights or nothing the only things that work are the hazzard lights and the head lights but nothing else. how would i test it to see if every thing getting power and what else should i do.
woki,
Nov 21, 12:17pm
Unplug it , plug it back in , jiggle it about a bit and then try again !
friendly_prawn,
Nov 21, 12:29pm
define:pluged !
jsbike,
Nov 21, 4:27pm
even without the ecu plugged in, it should still turn over
antiri,
Nov 22, 8:52am
i have checked for power to the fuse box and there was power. jsbike the loom didnt came with the starter motor loom or the knock sensor!
jsbike,
Nov 22, 9:06am
the knock sensor loom wasnt in there! no starter motor loom as that's seperate from the engine loom. I have always used the orig starter motor/alternator loom that was in the car, it goes from the starter and alternator up to the relay/fuse box on the drivers side of the engine bay. rb20e, 20det, 25de starter looms are all the same
fletp,
Nov 22, 9:11am
Check that the gear lever. is in Park
antiri,
Nov 22, 9:25am
its manual and could i be becoz it ust to be turbo so had a turbo timer
jsbike,
Nov 22, 9:33am
do your dash lights come on now!
antiri,
Mar 27, 4:02am
yea it was there dw i got mixed up and im going to short the turbo timer plug
