03 caldina torque converter shudder
nj01, Nov 19, 5:41pm
car has a slight shudder at idle while in drive but smooth thoughthe gears, maybe just needs a a/t fluid flush! what you guys think!
mm12345, Nov 19, 5:50pm
What are the revs at idle!
If a bit low/variable, then probably the common ( to toyota ) gummed up IACV in the throttle body, and nothing to do with the trans.Easily fixed.
nj01, Nov 19, 5:55pm
between 800-1000
nj01, Nov 19, 6:17pm
its revs in gear are more like 500-600ish in drive
mugenb20b, Nov 19, 6:47pm
Clean out your T/B and IAC valve with some carb cleaner.
nj01, Mar 18, 1:07am
ok sweet, cheers
