check engine light means the car has loged a fault code . you have to get the morse code out when its in diagnostic mode to see what number the fault code is.
Feb 3, 5:48pm
L.M.A.O.
Feb 3, 6:58pm
what are you laughing you should know they morse the code just like subaru and older GM autodata has specific instructions but my monitor is broken and i dont want to waste this much time and effort to swap monitors back and forward to post pictures and all so this myght help explain http://autorepair.about.com/library/ts/obd-i/bl-dtcs-48a.htm
rlr29,
Feb 3, 7:01pm
Also posting from non-windows vista platform.
biddy6,
Feb 4, 6:52am
What does that mean.
mrysone,
Dec 6, 9:16am
did you check all the fuse panels- my98 caldina did exactly the same thing .was a 20a fuse from memory.and we traced it back to a fuse under the dash- there are 3 different fuse panels that i know of on this model
