LIfting a 4X4
jazzyjack1, Jan 20, 9:17pm
What is a good option to lift your 4x4 2-3 inches without speanding too much!
littlebuckrat, Jan 20, 10:19pm
jack!
unideck, Jan 20, 10:39pm
LMAO, good one :)
OP, pays to mention the vehicle you want to get lifted, year, model etc.
jazzyjack1, Jan 21, 5:50am
I deserved that comment, its a 2000 Jeep Grand Cherokee, want to put some Mud tyres on it but wnt to also look at lifting a little, can you put spacers on top of the springs!
mrfxit, Jan 21, 6:28am
Theres a multitude of different ways to lift 4x4's
All depends on several key factors as to which way you do it
Total height increase
Intended tyre size increase
Intended PRIMARY usage & secondary usage
Vehicle brand & exact model
Budget
All 5 above factors will have a significant effect on the "best practice" option.
Where are you parking it when not in use = shed roof height
Total lift = possible cert needed = mods to drive shaft/brake lines /diff breather systems/ steering,
speedo adjustment = ruc accuracy
etc
Not hard but definantly needs a bit of realistic planning to get it right
mrfxit, Jan 21, 6:33am
Most small lifts on older 4x4's are simply swapping out the body to chassis blocks for taller blocks.
If you can do that would be easy=ish and wouldn't effect your suspention if only going 1" or 2" & wouldn't need a cert.
I suspect yours could be a monoque chassis so that option may not work.
Taller springs will limit total downwards travel & proberly need a cert plus wheel alignment.
petermcg, Jan 21, 7:35am
Come see me I might be able to help.
pico42, Jan 14, 5:18pm
