have just put a slim sub/amp in sons ute ,it has a remote volume type switch and when i turn it up all it does is droons. is someting wrong with it or how do you set it up!
spead,
Nov 26, 1:39pm
I suggest dont then your son wont get the attention from Police the vehicle may soon deserve.
emnalana,
Nov 26, 4:17pm
is amp powerful enough to power sub! enough power from headunit!
trdbzr,
Nov 26, 4:21pm
what sub and what amp are you using! how did you setup the wiring! how did you 'tune' the amp! also how did you run the wiring!
chevygirl1,
Nov 26, 5:02pm
its a fusion slim amp and sub built as one unit.sony xplode head unit.earthed to chassie from amp,fused power from battery.remote wire for power.
chevygirl1,
Apr 10, 11:43am
plus the two rca cables
