Possible alternator problem!
jamstew, Dec 2, 2:30pm
When I indicate the headlights get dimmer and brighter, corresponding to the indicator flashes, and when its on turbo timer and i lock it, the engine almost dies when the indicators flash.
What causes these very minor but intriguing symptoms!
1996 Subaru GT-B
richard198, Dec 2, 3:42pm
What's the status of the battery! Fully charged/13.4V+!
mugenb20b, Dec 2, 3:43pm
Check you battery terminals first, make sure they are clean (and not just on the outside) and tight.
richard198, Apr 24, 3:05am
Presumably no dash warning light! (working okay!)
If battery checks out okay as well then put a volt meter across the out put of the alternator while the car is idling. You generally should get at least 10v.
Less than 10v out put is a bad, bad alternator.
