1992 Mitsi Galant, 2.0 V6, Auto, has an isssue, sometimes wont start, when it does it runs rough and wont rev well, cough and splutters.I got it like this for something to play with, the old owner thought it was stuffed fuel pump.thoughts before i pull it out!
n3d4sp3d,
Dec 4, 5:23pm
what is the condition of spark plugs leads and fuel filter. has cam belt been done recently!
sheepey,
Dec 4, 5:24pm
Clean out throttle body.
snj11,
Dec 4, 6:31pm
ok, all things i will now take a look at, thanks for your help so far
flybye_in_a_rx7,
Dec 4, 6:54pm
mine started fine but ran rough when cold. changed the distributor cap and fixed it. sounds like u have a diff problem though
m16d,
Dec 4, 6:58pm
Before you start ripping things apart, take a look at the air filter.
snj11,
Dec 4, 7:44pm
cheers will do
dasfi,
Dec 4, 7:56pm
mine had the same prob, i replaced the whole dizzy as it happend to be one of the sensors inside it, was fine after that, mine was an 1800cc v6, try that should work
phillip.weston,
Dec 4, 8:10pm
usually the dizzy fault is not starting up at all or cutting out completely, and when it does run it runs fine and smooth until it cuts out again. Like an on and off switch almost. I would be looking at the dizzy cap and rotor anyway as I had a similar rough running fault with my 6A13 SOHC engine.
wilgil,
Dec 5, 6:17am
If there has been any water near the engine the rear sparkplugs may be playing up. This used to happen to my wife's V6 Galant - it's a pain to remove the intake manifold, but while you're there, why not give everything a good clean out and replace the plugs!
mrfxit,
Dec 5, 6:53am
Yep as above.
Plugs Leads Strip & clean inlet manifold
See what happens after that. Certainly won't hurt to do the above & probably needs doing anyway.
snj11,
Dec 6, 6:09pm
UPDATE - thanks for all the advise guys, turns out it was the crank angle sensor that was the problem, got it scanned today as got sick of doing it the slow way ruling out the options
phillip.weston,
Dec 6, 10:00pm
nice! I had the crank sensor go crook on a 1600cc V6 Mirage also - unfortunately you have to remove the timing covers to gain access to the sensor - on the SOHC engine it's not too difficult.
mbmadman,
May 12, 5:00am
Its a mitsi. theres your problem LOL
