Vibration in 97 double cab hilux.
kerrylee1, Dec 11, 6:36pm
any advice very much appreciate, doing my head in. vibrates at 75km on wards, just been certified, have done new wheel bearings, new brakes,new tyres and balanced,new drive shaft hanger bearing,drive shaft balanced,u joints, all engine and gear box mounts good.motor runs sweet, running out of idea. may have a split personality and think its a ford. ( sorry ford lovers)
franc123, Dec 11, 6:39pm
OK so there must be more to this story, why has it been certifed!Has another engine been put in to it!Has the diff been changed, suspension lowered! etc etc.
m16d, Dec 11, 6:43pm
Ya got a bent back wheel.or axle.!
kerrylee1, Dec 11, 6:45pm
no, no, no, got certifed, went away for weekend in it, and vibration started up, no abit about motors etc, and have done all i can think of, hence why im asking for advice/help.
thanks
franc123, Dec 11, 6:47pm
OK but whats been modified that needed certing!
mugenb20b, Dec 11, 6:52pm
Rear drive shaft out of phase.
henderson_guy, Dec 11, 6:57pm
Certified = COF perhaps!
kerrylee1, Dec 11, 6:59pm
nothing, nz new , was unregisted for 6 years, just used as farm truck, went fine for 1st 500km, suddenly vibration. have spoke to toyota etc re problem, stillat a lost.
mrfxit, Dec 11, 7:10pm
Swap over your wheels for another set.
Not uncommon for a tyre to do that
Modern wheel balancing is not what it's cracked up to be.
mugenb20b, Dec 11, 7:13pm
Ahh.you may have lost a wheel weight, or the wheel weight may have shifted.
kerrylee1, Dec 11, 7:17pm
no, checked that out as well, sorry running out of ideas.
kerrylee1, Dec 11, 7:18pm
done, thanks any way
usdefault, Dec 11, 7:23pm
You did a 4 wheel alignment yeah!
mugenb20b, Dec 11, 7:25pm
How does wheel alignment affect vibrations!
usdefault, Dec 11, 7:31pm
You serious!
jmma, Dec 11, 7:31pm
Diff pinion bearings.
skin1235, Dec 11, 7:32pm
you did all of that to cure a vibration!
crazy, like re-piling the house to make the water run the right way in the guttering
sals11, Dec 11, 7:32pm
had same problem in 89 hiluxwas loose nuts in 2 of the drive shafts and large center nut in middle of drive shaft was loose and needed 1/2 a turn,,,Was told quite often wrong nuts and bolts used after repairs
usdefault, Dec 11, 7:34pm
Sorry should have been more clear.did you get a 4 wheel alignment/balancing.
OP answered yes.
kerrylee1, Dec 11, 7:39pm
hope not, but thanks, could be on to something, everything quite at back, but worth a crack. cheers
kerrylee1, Dec 11, 7:40pm
all done, but thanks anyways
skull, Dec 11, 7:42pm
I'm assuming this is not a vibration you can feel thru the steering wheel so shift the rear wheels to the front and see if it alters the vibration at all. Do you have any sensation at all about what type of vibration it is! Wheel vibration, driveline vibration, engine vibration!
kerrylee1, Dec 11, 7:48pm
feels like driveline, everything new in front. thanks for input, very frustrating.
jonthefisho, Dec 11, 7:53pm
They have a bad habit of flogging out driveshaft crosses if you don't grease them regulary.
jmma, Dec 11, 7:56pm
Front hubs engaged!
