Mazda b5 dohc overfuelling!
a.woodrow, Dec 19, 2:55pm
just put back together after valve job, floods itself instead of firing up, if I cut off fuel supply and spray a bit of ether it fires up. thoughts! Mazda familia 89 b5 dohc :) in white not blue
mucchu, Dec 19, 3:09pm
Timings out
a.woodrow, Dec 19, 3:12pm
Yeah I've checked it - thought that too, especially after head work. Also should add vehicle tow starts and then runs normally, just no good self starting.
mugenb20b, Dec 19, 7:07pm
Can you start the engine OK with your foot flat on the accelerator!
jmma, Dec 19, 7:11pm
A bit of the green sticker fell into the air cleaner intake (o:
franc123, Dec 19, 7:31pm
You've reconnected the coolant temp sensor and/or air intake temp sensor if its got one correctly!
a.woodrow, Dec 23, 5:52pm
Yep checked connections. It is somewhat improved over the last few days, will start on its own if it has just been running, won't start otherwise unless I clamp off the fuel line and wind till it fires, then release the fuel line. if I try winding over normally it just floods.
a.woodrow, Dec 23, 5:55pm
nope still floods
blueband1, Jul 4, 10:04pm
how old is fuel! Did you disconnect hoses from pipes or from the rail might be the wrong way around.
