Not a bad vehicle if thats what you want, check for any rattle or knocking on cold start-up as they can develop in timing chain/cam timing area(turbo engine), also check for blue exhaust smoke as the turbo seals are known to give problems, mazda should fix if still under warrenty, both things are not too common though. run on 95 octain or higher.
petal-pickle,
Jul 26, 4:07am
also which petrol to use!
