The Laser/Mazda stud is slightly different than what you've mentioned Rob. I used to have some under the house. Will take a look later-on. They're pretty well obsolete now.
whqqsh,
Jan 1, 6:25am
Have you advertised in the car parts wanted section on here!
brokebloke1,
Jan 1, 7:13am
Thats almost as bad as fitting Commodore wheels to a HQ-WBsure they fit but not correctly as PCD is different one is imperial the other metric. seen as least 3 HQs on side of road with broken wheel studs.
leanne1980,
Jan 1, 7:13am
No, I haven't - didn't realise there was one! Thanks for that!
leanne1980,
Jan 1, 7:15am
Thanks, that would be great - We currently have Ford Laser wheels that don't quite fit.
leanne1980,
Jan 1, 7:16am
The husband has just informed me that the trailer currently has Mazda 808 rims which are bent.
rob_man,
Jan 1, 7:29am
Laser are Mazda, I would expect those to fit.
faybian,
Jan 1, 8:06am
how much you want to pay i have sum
socram,
Jan 1, 8:45am
Try your local mag wheel or suspension specialist, even scrap yard. They tend to have piles of unwanted steel wheels and even mags.You'd be amazed what is around as long as you take some form of measuring devive or even a card template with you as they won't usually be sorted or labelled.
lookoutas,
Jan 1, 1:50pm
That's why Laser ones wont fit. Saves me going out in the rain and climbing under the house.
If they happen to be going on a boat trailer that goes into salt, you should be finding a mag with the right off-set and re-position the studs.
bellky,
Jan 1, 1:57pm
toyota ke20 rims are 4x110 too
1ollie,
Jan 1, 9:54pm
NO they are not! they dont fit well and I would not recomend it just because people have done it! Mazda is 110the others are 108
1ollie,
Jan 1, 9:56pm
Whos said anything about a Laser! they are FWD and are 4x114.3 not same as RWD Mazda 4x110.
1ollie,
Jan 1, 9:57pm
Laser was only same as 323/Familia when they changed to FWD in 1982/3
1ollie,
Jan 1, 9:58pm
But only came in 12" not 13"
lookoutas,
Jan 2, 5:56am
"Shit" - I didn't realise they were that new ollie. Sorry - wrong decade. Must be getting too old. Your fault Rob.
rob_man,
Jan 2, 6:03am
I thought they kept the same pattern as the early Mazdas with a different offset.
rob_man,
Jan 2, 6:50am
Boating on the Whanganui!
leanne1980,
Jan 2, 1:38pm
What do you have! Don't want to pay too much as it is for a trailer. Need 3 (2 for trailer, 1 for spare).Are you able to post a pic!
leanne1980,
Dec 31, 3:30pm
My husband is on the look out for some 13" 4x110 stud rims to replace some old ones on a trailer. Have had no luck looking on TM, just wondered if the forums have any ideas where else we could look!Tried our local Pick a part, and have looked around Tauranga.
Thanks for any help you can offer!
rob_man,
Dec 31, 3:40pm
Escort, Cortina and Hillman Hunters and Avengers have that same pattern.
Dec 31, 5:57pm
Escort and Cortina should be 4 x 108, not sure about Avengers.
rob_man,
Dec 31, 6:54pm
I have swapped between them in the past.
generalace,
Jul 30, 2:00am
yeah you can but it doesn't do wonders for the studs, it may only be 2mm overall but still not a great idea
