1996 mitsubishi lancer engine noise
hondalova, Feb 15, 8:43pm
Hi, i have a 96 lancer 1.5 DOHC. the engine knocks when its cold then it goes away. but it does it when im driving aswell. and very loud when under load at low rpm. how could i fix it thanks! ive been told it could be the crap oil filters by ryco or the oil.
franc123, Feb 15, 8:46pm
probably noisy lifters, practically standard on Mitsis that old.New oil and filter and some Proma MBL8 will sort it with any luck, unless you're motivated enough to track down and replace the noisy ones.
hondalova, Feb 15, 8:49pm
so its noisey lifters. ok. how much would they cost! either O/E or A/M parts!
intrade, Feb 15, 8:57pm
what fuel do you run 91!
hondalova, Feb 16, 6:23pm
91 petrol. its like a clicking noise for idling cold.
lugee, Feb 16, 8:25pm
Yeah thats really common on an old Mitsubishi. Parts probably won't be a hell of a lot, but the labour will be up there.
intrade, Feb 16, 9:02pm
if its hydro lifter fill in promar additive.
skylinegtr_r34, Feb 16, 10:11pm
should run it on 95. i have a 96 mitsi and goes very well running on 95 :) had no problems with it
1grasshopper, Feb 17, 5:14pm
Just fixed our noisy tapping noise in our 94 Mitsi by replacing the worn lifters (we had the head off anyway).We run ours on 95 petrol (but its turbo)
hondalova, May 8, 11:49pm
Where do i get Proma MBL8 from!
