Astra door panel
cameocooper, Feb 22, 3:41pm
anyone how know to remove door panel from 2000 astra, windows has jammed
intrade, Feb 22, 3:52pm
you usually undo all of the inner doorligning you want to look for hidden screws under push on clips etc.
lookoutas, Feb 22, 4:24pm
Recalling the process of every single vehicle is a big ask.
Usually do it by using the eyes & ears in the tips of my fingers, and undo every screw one comes across. Probably need to carefully lever the panel off that houses the window switch (having to assume it's electric) There's usually a couple of hefty screws in that area.
marcos1, Feb 22, 5:30pm
Windows or window!
smac, Feb 23, 6:29am
Wind up window or electric! On the wind up the winder circlip is the issue. I'll TRY and explain but only if I have to!
jono2912, May 20, 1:04am
Get a rag. Hold diagonal corners of it and slide it up to winder and slide back and forth. Now, they are nicked named jesus clips and you will find out why if you don't take care of it.
