Searching for seatbelt for toyota sprinter-no luck
mandy1968,
Jan 16, 4:54pm
Have called wreckers and car parts places and searched on parts for sale here but still no luck. Does anyone out there have a drivers side seatbelt for a '95 AE100 !
unbeatabull,
Jan 16, 5:42pm
Sure its not AE101 your looking for!
gadgit3,
Jan 16, 5:45pm
Thought about fitting a new after market belt!
gadgit3,
Jan 16, 5:47pm
AE100 is a import sedan. Fitted with a 1.5L normally
mandy1968,
Jan 16, 6:14pm
It is an import as far as I know. Sprinter SE Ltd. 1.5L. I looked under the bonnet and see the badge says AE100
Jan 16, 6:14pm
mandy--I know a guy that sources belts out of japan what you need to do is wright down ALL the letters and numbers written on the belt tag--Thats the little white cloth tab hanging off the bottom of the belt on the pillar
mandy1968,
Jan 16, 6:15pm
Oooh! you got me wondering now.it's a recon motor so the original may have been AE101 !
mandy1968,
Jan 16, 6:16pm
Have checked prices for new belts and so far looking at about $220 approx (different fittings though!)
Jan 16, 6:17pm
THE CAR doesn't really matter--its the BELT that matters. :-) One seatbelt can fit about 6 different models--the secret is finding out what yours fits.
Jan 16, 6:18pm
heck thats cheaper than a second hand belt for a lot of late model stuff. Look if you are lucky youll find a matching belt for anbout $150 which will fray the same as the old belt has---I'd go the extra for a new one then no more woirries
mandy1968,
Jan 16, 6:25pm
Old one isn't frayed.it's not retracting.
Jan 16, 6:26pm
well then thats easy to fix if its just the common issues. --a clean up -a bit of lube in the right place and good as new
mandy1968,
Jan 16, 6:27pm
How do I find out which ones fit!
mandy1968,
Jan 16, 6:28pm
True! I thought maybe the spring had busted or something! Do I just take it to a seatbelt place to get checked out!
Jan 16, 6:33pm
Does it not retract at all or is it really slow and gutless! Theres simple stuff YOU can do before going that far. WASH the belt -PULL IT RIGHT OUT and scrub the bit from the wall as far as you can reach with HOT soapy water. SCRUB the bit of plastic that the belt seems to be coming out of with hot soapy water--you want to dissolve the body oils and grease -theres other easy stuff you can try but a wash often works wonders
twink19,
Jan 16, 6:33pm
seat belt services
moosie_21,
Jan 16, 6:34pm
Probably a Celica or Corolla one might fit. Just a matter of fitting and seeing.
unbeatabull,
Jan 16, 7:21pm
If its just slow to retract, clean all the gunk off the top runner and silicon lube the crap out of the belt, makes them retract like new in about 5 mins work (depending if/how much trim has to come off to get to top runner)
mandy1968,
Sep 25, 5:55pm
Thanks so far for all of your replies. It was fully extended and would not retract at all.like it's jammed.
