Terrano TD27 turbo.
haze1979, Jun 30, 9:54pm
Just replaced the fuel filter and had a guy with the same wagon tell me that there is another filter/screen that needs to be cleaned. Apparently it's on the top of the pump or something!
intrade, Aug 17, 8:40am
if it runs fine then dont worry about the one in the pump. you should be more worried that the pump will leak if you dont use a additive like wynns edt to prevent seal shrinkage .
