Holden diff help please
Page 1 / 3
maz61, Jun 20, 6:38pm
right! i have a beach buggy with a 202 3 speed manual gear box, the pinion shaft in the diff head is stuffed! now im not sure what this diff is out of, so far i have come to the conclusion that it is a banjo Holden diff with 30 fine spline axles, my question is what type of Holden would this diff likely to be out of! cheers
jmma, Jun 20, 6:42pm
Prob the same as motor and box, maybe HQ,
maz61, Jun 20, 6:53pm
the motor is a red 202 motor, im not sure what thats out of eirther maybe torano!
jmma, Jun 20, 7:00pm
Torana had 4 speed, what spring set up is on the diff! Photo maybe!
sr2, Jun 20, 7:23pm
Looks pre HQ to me, what stud pattern is it!
maz61, Jun 20, 7:24pm
5 stud, cheers
jmma, Jun 20, 7:33pm
Yes pre HQ, could be any from eh to hg, is there a ratio stamped on the crownwheel!
maz61, Jun 20, 7:43pm
914! does that sound like anything! thanks
jmma, Jun 20, 7:50pm
No, 3.25:1or something like that, are you sure on your axle spline count!
Do you go to Porirua much!
monzaman, Jun 20, 7:50pm
Looks like my hiace diff,it's not bango type borg warner diff as used holdens,falcons and valiants.
jmma, Jun 20, 7:58pm
Could be on to something there, Older hilux have 30 splines
maz61, Jun 20, 8:00pm
cant find anymore numbers on the crownwheel, all there is is 94914, and just did a recount on the splines and yes there is 30, no dont go to porirua much but can do its only down the road lol, cheers
maz61, Jun 20, 8:05pm
that's really throw-in a spanner in the works lol
monzaman, Jun 20, 8:11pm
I'm sure it's a hiace diff now because in 1st pic to left of diff head hole is the mounting bracket for the brake bias load lever/rod-correct!they are avery strong diff-8 inch and v popular for drifting ect.
lordv81, Jun 20, 8:13pm
Does not look like holden.Count the teeth on the crown wheel and pinion,then devide crownwheel number by the pinion number.At least you will know a ratio to go with the spline number.
skully13, Jun 20, 8:15pm
Doesn't look like a Holden diff, due to the mounting flange for the drive shaft and the 30 spline axles.
maz61, Jun 20, 8:18pm
you could be right mate as i really have no idea what type it is just going on what the guy though it might of been when i bought it and he says he thinks holden but yeah he was a bit vague on it lol that bracket that you are talking about had nothing on it so i dont know what that bracket is for but sounds like you may of nailed it! hang on i will take a closer pic
yeah i wondered about the mounting flange too
snoopy221, Jun 20, 8:19pm
it's got STUDS.not bolts. show us some pics of the brakes-wheel cyl,shoes adjuster-springs etc.K
Personaly it looks NON early borg warner as it also has locking plates on the crown wheel bolts
snoopy221, Jun 20, 8:20pm
could even be early 2wd nissan ute.
neville48, Jun 20, 8:24pm
Holden diff would definatly have the ratio marked on the crown wheel, most popular being 3.55:1 but it would be stamped in.
maz61, Jun 20, 8:27pm
sweet hang fire mate i will go and take a pic, cheers
monzaman, Jun 20, 8:36pm
Yes that's it exactly as in my 98 jumbo hiace even,ratio number is usually stamped on crown wheel but very small and not always,also colour coded on nut end of pinion-prob worn off by now.
snoopy221, Jun 20, 8:45pm
Yep hi ace.
monzaman, Jun 20, 8:47pm
brakes same to
