Battery keeps going flat help
tonyrockyhorror, Jun 15, 2:05pm
Someone doesn't know what they're doing.
Was this a NEW battery!
laneyjan, Jun 15, 2:59pm
check boot light is off when boot is closed
bigracket, Jun 15, 3:36pm
As new!
bigracket, Jun 15, 3:43pm
And your two batteries were old !
crzyhrse, Jun 15, 3:47pm
And glovebox. And interior courtesy lights. The switch may be borderline so it's only turning on the drain seemingly at random.
What you can to is hook up one of these http://jaycar.co.nz/productView.asp!ID=AB3456&keywords=piezo&form=KEYWORD to your boot lamp fitting using the pulse wire. It will provide an audible alert if the boot light is on at any time. I have one permanently fitted (using the pulse wire) because my boot switch is non-adjustable and even though the boot is closed if it's not latched it still looks latched but the light is on.
crzyhrse, Jun 15, 4:05pm
What's what got to do with what!
crzyhrse, Jun 15, 4:08pm
Condescending. And I'm not being.
eddiedean, Jun 15, 5:15pm
Geez i'd take that offer if i was him. That's a great offer
iman007, Jun 15, 5:28pm
is the radio turned off,sometimes if i turn my radio in my car down, and talk to someone, i might forget to turn it back up.Radio still drawing power when car is switched off.Happened to me 2 or 3 times.Dont turn radio down now, only off or on!
Just a thought Vaughan!
im_andrew, Jun 15, 6:56pm
Get a multimeter, switch it to the AMPs setting, and with all your accessories and ignition turned off, connect it in series with the battery.
johnf_456, Jun 15, 6:58pm
Yup and the old fuse trick as well of identifying which circuit is chewing the juice.
crzyhrse, Jun 15, 7:21pm
but that's just me.
bae13, Jun 15, 7:25pm
could have an intermittant draw. seen that a few times lately
bonjt, Jun 15, 7:26pm
Make sure the battery is charged for this test,Open hood,turn key on, then have a look if one of the cooling fans for the radiator is going, if so then you have a faulty circuit,The fans should only operate when temp is slightly high,and with a faulty circuit the fan will continuosly go.Turn key of and check if fan is still operating,,its so quite you cant hear it.Good luk G
crzyhrse, Jun 15, 7:30pm
That depends on the vehicle. And if the fan isn't going with the key off that's all you need to know.
muzzaandmich, Jun 15, 7:42pm
all the guessing in the world wont fix anything ,,take it to a auto sparky .dig deep into your pocket pay a few bucksall sorted
elect70, Jun 16, 2:41pm
Strange things happen I had a newbluebird wagon that the battery would go flat even parked for a hour ,wouldnt do it every day but usually once a month . I checked everything, replace all the light bulbs,tested the alternator , had battery load tested ,put amp meter on it when off . Never did find out what it was . Sold the POS1 year after thewarranty ran out .
crzyhrse, Jun 16, 3:56pm
That's much better value than actually finding the problem first.
Make sure the terminals are clean and tight.
bigracket, Jun 16, 10:30pm
Keen to see the result of this one.
divermark, Jun 21, 9:11pm
Lots of short trips !The battery might not be getting a decent charge. I've heard that it can take 15k's to replace the power used to start the car.I killed a $400 battery this way after two years of 7k max trips to work & back. battery guy suggested getting a 'smart' charger, so I plug the car into the charger every month or so (more in winter) to top up the battery charge. no problems now even with a cheaper battery.
snoopy221, Jun 21, 9:14pm
Seen em b4. usually horny houers.
(seems most auto sparkies seem to forget a crook horn has permananent power and can do the ole flattenning.)
solarboy, Jun 21, 9:49pm
OK, that was 5 days ago.He said in post one that an auto sparky had said the alternator was fine and there were no "phantom" loads so that left the battery which he'd replaced with "2nds" .He;s not been back so he's either walking in from the outback still or too busy driving his now reliable car !
for_an_angel, Jul 11, 1:13pm
I'm going with the too busy driving option lol or the OP would have been back to hunt down Kazz for some pingers haha
