Yep, bore water is a killer kaz. I've had 2 cars in the past that died as a result.
jason18,
Jun 17, 8:33am
Same problem I get with shower glass. Bore water has a huge amount of minerals in it causing huge scale build up on the galss. Can just imagine it in a radiator.YUK
johnf_456,
Jun 17, 8:34am
Good advice had this with a few clients cars after digging deeper.
ntalke,
Jun 17, 9:16am
When I did one of my vehicles I was warned not to use tap water
Supercheap has containers of De mineralized water for this purpose
franko171,
Jun 17, 9:24am
put buckets out and get rain water
jcwholesale,
Jun 17, 9:38am
kaz I think the heading is a bit bias as the same would have happened to any vehicle. In saying that those motors are prone for cracking heads but usually at about 140000kms.
Jun 17, 10:22am
The 2.5 litre turbo diesel Mazda/Ford engine is actually quite good. A lot of farmers in our area have them, and every 2 years we pull radiators out and get them rodded out. Those engines will easily do 400k with regular servicing and maintenance. The ones that do crack heads are the ones that are not looked after, where farmers treat them like bulldozers in paddocks. Grass, seeds, mud and cow $hit block up the radiator fins and pop goes the head.
xacoon,
Jun 17, 10:46am
radiator core itself is partly to blame, very small tubes, need a very small rod to clean them, so in turn beacause they are so tiny they block quicker than anyone would expect a modern radiator to block.
xacoon,
Jun 17, 4:36pm
thats problem solved right there.
mrfxit,
Jun 17, 5:25pm
LOL. well bugger me . Bit over the top having to pull the radiators out for rodding every 2 years, points to a manufactures firk up for sure.
crzyhrse,
Jun 17, 6:56pm
Rainwater is filthy. It picks up all the dust from the atmosphere when it falls. Never use it in batteries.
mike77,
Jun 17, 6:57pm
Another my mate story . but owned a 03 mazda from new, and meticulous regarding servicing, popped the head at 155km was only 3 years old. High kms from mainly doing runs from nth to sth island no towing either!. but like ya say, hard water probably makes it worse. 5k over the factory warranty, but from memory they covered it.
crzyhrse,
Jun 18, 9:33am
How many people even know coolant needs changing.
johnf_456,
Jun 25, 7:44pm
or the sort that put in straight water, then wonders why it wrecks havoc.
