Hey just woundering i need a exhaust manifold with a wastegate flange 35mm but they only have ones with 38mm ones can you get the 35mm wastegate to fit it somehow
glenn_michelle,
May 30, 6:57pm
without seeing the manifold in question you could have the flange cut off and re weld the correct size one on,if it's a cheap stainless manifold i wouldnt bother rewelding it
snowballs4,
May 30, 7:14pm
just get a tial 38mm waste-gate and forget about it, they are very reliable and since its a 38mm flange it would be cheep they are coming out in v clamp now, also if the manifold is under 2mm thick and it is stainless, through it away
guider1,
Apr 20, 10:52pm
Mates smallblock has "cheap" stainless turbo headers, $330 the pair. Has run them 2 full seasons so far & no cracks. Runs 8.60's over the 1/4 with a single Borgwarner S480.
