Mitsi 4g64 engine compatability.
big_oily, Apr 20, 7:23pm
Hi all you Mitsi Guru's - 1992 L300 auto exceed needs short motor or complete motor [rod tho' side] - what other years will fit and whats difference between auto and manual bell housings - can manual be modified to fit auto!
I know mitsi changes design by the minute so I need info to make correct choice - for instance two different width bell housings have been used I'm told.
Gratefull for any help, thanks.
phillip.weston, Apr 20, 7:28pm
Being a 92 it'll be an 8V motor, but being in a commercial vehicle it'll be a wideblock bellhousing pattern. You'll need to find another 2.4 8V from a 91-93 L300/Delica van. You could use a 16V 2.4 from a late 93 onwards L300, Triton or Delica L400 but you'll need to change over the wiring loom, ECU and air flow meter to suit the 16V engine.
phillip.weston, Apr 20, 7:29pm
the 2.4 in the L300 will have the same bellhousing between autos and manuals. The 2.0 in RWD config will be narrowblock however a 2.0 4WD will be wideblock also. FWD 2.4 (ie Hyundai Sonata, Magna etc) will be narrowblock.
big_oily, Apr 20, 8:04pm
Thanks a million Phillip - how much loom change reqd if using 93 onwards - only on immediate engine area or more involved!
phillip.weston, Apr 20, 8:06pm
don't know - never did it myself. Ideally you would want to find another 8V 2.4 L300 motor.
big_oily, Nov 22, 4:43pm
Thanks for that - going for the short block option - will head etc bolt up to a year 2000 engine block!
