Fords stereo security help needed 1993 ford telsta
carmad50, Mar 17, 9:41pm
help please we ve got a 93 ford telstar ghia paul radisic special car with a 3 in one stereo thats security coded took the battery out after it went flat on me now it wont play for longer than 3 minutes at a time and resets got the code from macauleys ford down here in invers but yerp nice day for where or how to reset the stereo up again which button do i press ms ld or sumthing else
gee its quiet when hubby cant play his acdc or black betty loud lols
please help
nave12, Mar 18, 5:57am
Take a drive back to the Ford dealership and see if they can work it out for you or any one that is technically minded,also if you have a manual it would show you how to do it in there.
carmad50, Mar 18, 8:29am
it wud be good if they knew how to do at 80 buks a hr or even had a manual thats why im here asking if anyone knows but thanks anyway
carmad50, Mar 19, 11:17am
yep tried thatguy at ma cauleys got code of 111 5 um yerp tried n failed must be certain keys in it to press to load cde or even get it to work normally frustrates me should be easy as
mr_lovebug, Mar 19, 11:32am
I have heard that you can remove the code altogether,just remove the unit & put in a freezer for 8hrs.
Then the coded days will be GONE!
mr_lovebug, Mar 19, 11:33am
Just check 1st,thats what i heard works on the alpines.
Learned that at a poly tech.
carmad50, Mar 19, 6:13pm
considers taking dash out to get rid of 3 in one stereo and smashing it to bits installing a new one with a boom box amp etc
nave12, Mar 23, 7:53am
Could you put up a picture(good clear one so can see all your buttons) so we on the motoring forums can get a look at what your stereo looks like(set up),i can also put up a pic of it if you take one and show others that i know and see if they can crack it for you.
carmad50, Sep 25, 5:42pm
nave yerp can do loook here 2morrow for the link
