Toyota Hilux rear axle, anyone know if.
aj254, Feb 8, 4:17pm
An axle off a late 80's shape hilux is the same as the next model up!
My '94 hilux has a bent rear axle, possibly from the last owner as I don't recall hitting anything, and I know about a few older shape axles sitting around.
intrade, Feb 8, 4:19pm
well have a look and a tape mesure. thats how i figured out if the old engine fits the newer model and it did but who knows . if you dont look you wont know
mrfxit, Feb 8, 4:21pm
Surf or small Hilux
1989 is when the Surfs changed from leaf to coil spring rears
aj254, Feb 8, 4:22pm
Easier checking from behind my keyboard.
Oops should've said, its a 2wd petrol.
mrfxit, Feb 8, 4:56pm
In that case yep probably will fit ok.
Best to check ratio of both units first
